1985 150 hp evinrude carbs
quackshot
This engine has rough idle but runs good at higher speeds. How do I sync the carbs. and what do you suggest to clear up the rough idle?
Barnacle_Bill
Re: 1985 150 hp evinrude carbs
Your low speed jets may have junk in them and the carbs need a good cleaning. The carbs are synced thru a procedure called link & sync. The prodecure is in your manual and must be done in the order given.
