DixieBoatN
Thread starter- Joined
- Mar 17, 2009
- 41
Everyone,
I recently purchased a 1985 1800SS Hydra-Sports. It has a live well under the seat in front of the center console. The live well only has one hose hooked up to it and only has one hole in it to hook up a hose. From what I can tell, the hose runs back to a pump and then out of the stern. I thought that a true live well needed one line coming in hooked up to an aerator pump and usually dispensing into the well at the top of the well and a drain line going out? My line comes in at the bottom of the well and if you put water in the well, it just drains out of the rear.
Now, note that some previous owner cut the wires to the pump, so I do not yet know what happens if you turn that pump on. Once the rain here lets up later this weekend, I'll be hooking the pump back up and flipping the switch to see what happens.
Does anyone know how this system works?
Also, the trolling motor plug in the front does not work. No power is going to it, but I can't find where the wires come back into the fuse panel in the center console and they do not go back to the deep cycle battery. Does anyone know how this circuit was originally routed?
TIA!
TIA!
