My situation is this, I bought this boat last year, and have had a few problems with the motor. My most recent problem is that my tilt/trim will not work. I have tried charging both batteries in the boat, disconnecting and reconnecting the battery wires, and just can not get the motor to rise and lower. I hit the red button on the throttle, and there isn't even a noise saying it's trying to work. I had the boat out maybe 2 or 3 weeks ago and it sort of worked then. I was able to raise it to take the transom saver off, and then lower it when I put the boat in the water. Started up the motor, took it for a short drive out of the harbor with no problems, then when I reached a speed of about 10 mph and tried to trim the boat, it would not trim and the motor would not rise. I slowed down, and could raise and keep the motor lifted, but as soon as I went faster, the motor would drop. I had just moved my boat to my new home, and tried to lower the motor and it will not move at all. there is no noise, no movement, and i lifted the motor to try and take the transom saver off and it stayed up, then when i moved it again, the motor dropped and is stuck in the down position. Any and all help is greatly appreciated. or at least some ideas to try and raise the motor till i can take it to a mechanic. Thanks in advance.
Ryan
Ryan
