slammed2000
Thread starter- Joined
- Jan 13, 2008
- 11
well i have a couple of questions. first i must say that 20 years ago i became an omc certified outboard mechanic while i was in school i did this for about 5 years and haven't used it since. however i recently bought a 25 hp evinrude that had been dropped and broken the lower engine case. i ordered a new one it will be here tuesday. so my first question is what else will i need to replace when i replace this part like gaskets and such. i know that i have to pull the powerhead to replace this piece. second questions is about the choke/primer valve. this motor has not run i a while and i am sure at very least the carb needs cleaned but probably rebuilt. however i tried to run it today and went through the basic things before i started making sure i had spark and good compression which i do. my question is do i need to pump the primer valvle or just pull it on. i cannot remeber. i got it to fire for a couple of seconds but not run for any length of time.
thank you
aaron
thank you
aaron
