1987sylvanoffshore
Thread starter- Joined
- Apr 7, 2010
- 46
I have everything hooked up with the exception of the "distributor to shift interrupt wire" and the "coil to ignition splice lead wire to shift interrupt switch" . I have already timed the motor and everything is fine on that part of it.. My question is..... which side of the shift interrupt switch does the "distributor to shift interrupt wire go to? I would assume negative. One side of the shift interrupt is positive and the other side is negative. The electronic choke wires are hooked into the shift interrupt switch as well. Also, does it really matter if its hooked up to the actual shift interrupt "switch" or the shift interrupt "box". And last but not least do i really need to run another 12v wire to the shift interrupt switch
