1985 50hp Evinrude motor issues
HENRY
Here we go again.... unfortunately....my motor is crapping out again, same as before
It intermittently looses power at 3/4 to full power, and it's now starting to also run a little rough at low idle, it shuts down if I'm not on the throttle.
I took it into Ryan boats and they were not able to duplicate the problem, he said it ran fine at 1100 PSI on a dyno-machine with no failure. He thought the problem may be my prop????? $165 down the drain..... any suggestions? or mechanic???
When this happend a year ago I replaced the fuel filter and sparke plugs and it ran fine, now it's doing the samething. So far on my own I replace my primer buld and hose connections???
I'm in Torrance, CA
