1985 75 hp mariner power pack
bill29045
engine will not fire! anyway to check a powerpack to see if it is workin or not? :confused: :confused:
petryshyn
Re: 1985 75 hp mariner power pack
There is only one way to check a powerpack. Give it what it needs, and if it don't perform......pitch it.<br /><br />what it needs:<br /><br />>check all connectors, supportive wiring and grounds<br />>check kill circuit<br />>check coils<br />>check charge voltage<br />>check trigger voltage<br /><br />If the above are good, the pack is bad......<br />Anything short of these tests is just guessing....<br /><br /> :)
Mikael-Block
Hi <br />I have a 1984 75 hp Marina.<br />I had a problem some tome ago, and someone on this site told me that if :<br />3 plugs fire it is the box<br />2 plugs fire it is the stator<br />0 plugs fire it is the trigger<br /><br />that is if everything else is ok...<br />I try to find the old reply...1 year ago<br />my memory might be wrong...<br /><br />Mikael block
Mikael-Block
hi again<br />Found the old reply<br />" missing spark " march 2001<br />made a search on Marina 75 hp <br />the first one that was shown....<br />you might find some help there<br /><br />mikael block<br /> :eek:
