temple1975
Thread starter- Joined
- May 5, 2009
- 59
I purchased a new to me mariner seems to be fresh water only engine. Anyway I took it for a quick spin after I mounted to the boat, it idled fine and ran fine for a little run of about 75 yard then it sputtered and stopped. I tried a few times to crank the engine but could only get the engine to run with throttle the throttle advanced. I cleaned the carbs but still could only get the engine to run with the throttle advance. I just did a compression check and have 150 dead on across all four cylinders. I then inspected the plugs and found a small ring of rust on the #2 cylinder.
My assumption is that my water jacket seal is leaking water back into the cylinder ? IF my fuel was contaminated I would expect to see a small amount of rust on all the plugs ?
I certainly do not want to risk breaking exhaust bolts if I don't have to. But is there any other way to get water on just that plug ? I compression tested the engine before I bought it and did not notice the small rust ring before. By rust ring I mean like rust had been lightly brushed on by a brush not eating into the plug or anything.
thanks in advance for any advice
