OK so i need some help, I have a four cycle, 1985 75HP motor, 2 years ago it was rebuilt, tested then winterized. It was started again today, We cleaned the gas tank, cleaned the spark plugs and it started. Here are my questions
1. Is it 2-Stroke? (we mixed the gas today just to be safe)
2.is there oil I must put in the motor?
3. What about the bottom end lube?
4. I believe it is a 1985! i saw a 1985 on youtube and it looks the same
Here are the issues im having, It will not idol, I must use the throttle to start it, then i can quickly put it in gear and take off, if i try to go above half throttle it dies, in order to bring it to full i need to tap the choke on the key then it will run clean.
So any help or Advice for me would be great! thanks for all your help!
