1985 85 hp force when turn on ignition get nothing
nascar24
the motor ran a week ago when i shut it off had no problems took it to lake and got nothing when turning on ignition switch. all accessories work just no power to motor have changed iginition switch kill switch and all fuses and stil nothing even reset the circuit breaker on the motor still nothing battery has full charge is it possible the circuit breaker is no good the motor and boat had sat for two years before i got it It wont even click the choke when push in the key PLEASE HELP !!!!!!!
Barnacle_Bill
Re: 1985 85 hp force when turn on ignition get nothing
Did you check the 20 amp fuse under the cowling?
nascar24
yes replaced all fuses in fuse panel and the 20 amp under cowling
nascar24
well i figured it out on my own had 42 view of my post and only one reply and it had nothing to do with anything sure wished i would have gotten more replys to help out but anyway it was the circut breaker that was bad got new one and the motor lives again :D
