1985 90hp water in lower unit oil
mick3446
How do I fix my lower unit...the seal to the mid shaft is fine so the water is coming in some where from the prop. is there a wat to re-seal that area?
Mas
Re: 1985 90hp water in lower unit oil
The prop seal can be replaced, but I would get the LU pressure/vacuum tested to be sure. The leak can be as simple as not replacing the drain/vent plug washers.
MAS
emdsapmgr
As Mas mentioned the first place to check are the two drain plug seals. If they are fine, then any of these could be the problem: two (back-to-back) seals at the propshaft, an oring around the carrier, an o ring around the shift rod, o rings around the 4 carrier bolts and a single seal on the driveshaft. Any of them can leak, and if one is leaking, best to do them all.
