1985 Bayliner Capri 14' motor swap?
shig
Two questions here: has anyone swapped out the Force 50 on a 14' Capri for something else; and what's the max HP rating for the hull? I'd really love to put a Honda back there...Thanks!
NYBo
Re: 1985 Bayliner Capri 14' motor swap?
Welcome to iboats!:cool:
I think 50 HP is the rating for that hull. No Coast Guard capacity plate/sticker, I take it?
Keep in mind that the Force outboards are about the lightest weight for their HP of any manufacturer. A Honda 50 four-stroke is going to be much heavier, which may upset the handling of the boat; it will certainly reduce the passenger and gear weight you can safely carry.
An Evinrude E-Tec might be a better match. The weight is less than a four-stroke (but still a bit more than your Force), but it will put out a full 50 HP at the prop (unlike your Force).
giterdone72
Max rating is 50hp / 4 persons/ 780 lbs. I have the same boat. Still running the Force 50...
bigshink
I have the same boat. I don't know what condition your motor is in but when I got mine I did a few things impeller, fuel pump kit, plugs, wires, prop (because the other one was pretty bad). These motors have a bad rep but are actually really great motors. They are very easy to work on as well. If you need any help post on here or send me a message I would be glad to help. I just wouldn't swap motors unless you absolutley have to. If you do the basic maintenance on these motors they will last forever.
boater4696
I have same boat with a force 85 on it. I got it like that.:rolleyes: I was kinda worried about the whole 50 max hp thing, but i took it out and ran it. It does great and handles great. I wouldnt go no bigger that what i have now. mop:cool:
NYBo
Welcome to iboats. boater4696!:cool:
If you really have the same boat (have you measured the length?), you are way overpowered. The 85 is also significantly heavier than the 50, so your transom is under a lot more stress than it was designed for.
boater4696
Thanks. Yes same boat (13.5 from bore to end/back of transom). I'm doing floor repair (alot of rot) now also I'm going to beef up the transom while I am at it.
