1985 Beachcraft Cuddy Model 240C rehab
docben
Bought this boat recently and decided to at least get the stern area cleaned up and repair the old rotted wood. I have read many other restoration projects and links. I am not wanting to do the full boat at this point, just make the stern area solid enough for the rebuilt OMC 5.7L engine and 800 series sterndrive. Engine to be pulled this week, I hope. I know there is rot, not sure how far it goes toward the cabin and bow. Need the boat operational by March.
For sure, lots of work to do.
docben
Happy to report no sign of rotting in the transom area. The wood core is quite solid, despite the surface looking suspect. I think someone needs a new crystal ball.
So now that engine is out using a mobile crane, on to the restoration. Will need to mark where the old mount holes were and be sure the engine line up is accurate.
docben
Drill and check for dry shavings while you can.
Yes, thanks. Wondering if I can re-size the distances between the engine mounts so as to provide more room. The side that has the starter had a very small gap and near impossible to get a hand down and in between the mount edge and the starter motor. I assume the mounts will need to be marine grade wood with the fiberglass covering? Need to see what others have done.
matt167
I/O boats are are never easy to work on. The stringer drive transfers the thrust directly to the stringers. It doesn’t put much pressure on the transom under way, so the mounts are tied to the stringers. You can’t change that. And you need to make sure that the stringers are solid. The black tells it probably isn’t… as for wood. Just exterior grade plywood tabbed and glassed/ encapsulated with 1708 will do. Visit the restoration stickies
docben
Today some drill testing was done. Definitely more rot in some places but not in others. The major concern for me is where the engine sits between large stringers. White shavings are fiberglass and the darker ones wood rot.
Overall not too many places of extensive rot. Salvageable.
docben
Once I remove the old rotted wood, I plan to use pour foam to fill the spaces where the wood was. Looks like US Composites are the folks to buy from and using a 4 lb foam density is ideal.
the wood is structural. you need to replace the wood.
removing the wood is like removing your spine
docben
You old farts are killing me. LOL. Of course not! You have the disadvantage of not being here looking at what I do. and looking at 2 dimensional photos. To clarify...the rotted wood has ZIP, NADA, to do with the engine mounts. The rotted wood was a piece about 2 feet by 1 foot and max 1/2 inch thick and was over an air pocket. What I am doing, is putting in foam below where this wood was to fill the air pocket.
88 Capri (2022 SOTY)
I'm not able to physically see what you are but at the end of the day you don't want to create an artificial reef with your boat because of a timetable you have.
docben
Good advice, thanks. I have been reading most of the posts on resins, glass, etc. I will try and get better photos showing better dimensional views. Wondering if just using epoxy V poly is better. Seems people have their biases.
Further clarification...the rotted wood gets replaced with wood and foam below it.
docben
Picked up some resin at Lowes. Has anyone used this brand before? The label says its polyester polymer (trade secret), styrene monomer, silica.
