Hello all,
Not being one to back down from a challenge, and frankly needing something to do other than sit in front of a computer all winter, I looked at purchasing a Capri with a good motor, good hull and good trailer knowing it would need a complete floor replacement. I suspected stringers as well (didn't have shots of the floor just a description that there were "holes" in the floor) but hoped for a good transom. While looking at the boat (purchased off eBay from a charity) I began researching floor replacement and landed at iboats. That was 4 weeks ago and I'm watching soo many of the threads as well as reading and re-reading the hull extension and Sea Ray rebuild threads. After many late nights oo iboats looking and learning I decided to buy the boat ($600 - figured if it all went really poorly I could sell the motor and trailer for that much more or less) and promptly drove from Ohio to Wisconsin to get her. I got her home on the 17th and this is what she looked like:
Lol, when they said holes in the floor I didn't expect that. More of the floor was missing than was there. Oh well, made tear out really easy which I started immediately the next night, reading forum posts for guidance and info while making progress and forming a plan. I've read so many forums I feel like I know some of you. Friscoboater (Jay) your thread and videos (and attitude with everthing from the boat to your Mom) are an inspiration. Woodonglass and Oops I'm hoping to get some response from you guys as I am sure I'll have some questions as I go as well as soooo many of the other forum members (pmccraney I loved the animation video) that have provide so much on the info that I'm now trying to swallow in a short period of time. So with a bit of work each night and weekends this is what she looks like now:
Done with the cutting and really close to done with the grinding (thank goodness). I'm actually starting to get used to the itchy writs and hands - haven't found gloves I like yet using the 4 1/2 grinder and now it seems like there's no sense I'm so close to being done.
So, now it's question time. I live in SW Ohio and its cold. Even with the boat in the garage temperature is a huge concern. I have a torpedo heater and can raise the air temp to 75 or 80 but the surface (mold) temps will be significantly lower, in the 50 degree range I would guess. And the air temp will fall as I know I won't be able to keep the heater running with the fumes. So, question 1 - Is there a "minimum" temp to glass and if I 'm within that range what special steps do I need to take? I will be using poly resin. I know that I can go up 50% on the MEKP but US Composites (where I plan to buy from - there's only 1 local supplier that I've found so far and the prices are slightly higher) mix sheet says I can go up 50% but doesn't recommend temps below 60 degrees. I need some input here on this one. I guess I could wait until early spring to do the glass work and start on the seats but I really don't want to unless I have no other options. Besides, I'd hate to "finish a seat and not have it fit the new bases I have to build. Just seems liek a bad idea to do seats before construction. I read the hull extension (yes all of it - and Oops I'm so going to copy that Bayliner interior you did) and I know that work was done up north in the cold but Oops said many time he "stoked up the stove" and the space looked much larger than what I have - further from the material/fumes - so I suspect that the temp was much better than what I think I will be able to do. So ideas, comments, theories, working knowledge. Let's have it guys.
Thanks all,
Tony
Thanks all,
Tony
