Not for sure how long this boat sat before I got it. The guy I got it from traded for it and knew nothing about it. Things I have done to it,
New fuel Tank, New fuel line and Primer bulb, Rebuilt Carb. New Fuel pump. Bothe new coils, New wires and spark plugs.
Kinda hard to startin the water. When at the lake it will take off good and pop ( Not for sure if thru carb or exhaust ) Then after 20 or so feet it will start to slow down. to a little above an idle. You can wait and try it again and will take off and do the same thing. If I leave it on the trailer and back it in the water and leave it in netrual and hold the throttle wide open it will do the same thing. Run for a few then slowly die down. I'm at a loss. The motor looks good and clean, I am sure it's probably something simple. Any suggestions would be great.
Or else I may fill it with dirt and cedar trees and pull the plug and use it for a crappie bed next season..
Joey
Joey
