1985 evinrude 25hp
Dillz
Been using boat for a while and everything was perfect took it out all day shut it off to go swimming and when I turned back on it started to go perfect then out of nowhere started acting up. Carb looked clean replaced all the fuel lines not sure what else to check, maybe bad gas? Just filled it up that day.
  • IMG_3619.MP4
Dillz
I tried that couldn’t really pump it to much it was to hard, it’s perfect at idle and going slow only when I try to get into it that happens
Dillz
I did clean the carb do you think the float maybe got stuck causing the primer ball to stay hard?
oldboat1
Check the float valve underneath. Newer kits contain a wire hook to make sure the needle comes up with the float, opening the valve for more fuel.
