1985 evinrude 35 will not turn off
sambrigman
my 35 will not turn off with the key, i have to choke it off. its not in the controls, It does not have the purple and black wire. any suggestions? thanks guys... sam
boobie
Re: 1985 evinrude 35 will not turn off
The black/yellow wire is the stop circuit. Check that out. Grounding that wire out stops the mtr.
Joe Reeves
In conjunction with "boobie's" on target statement......
The kill circuit is: Black ground wire from powerhead to powerpack, black/yellow wire from powerpack to raised "M" terminal of ignition switch, black wire from other regular "M" terminal of ignition switch to ground. Check the continuity of those wires if they're attached properly.
