1985 Evinrude 40hp fuel pump type?
Kettler
The VRO pump was taken off the engine I purchased and is now a premix engine. The former owner used Part #393648 fuel pump, is this the right pump for this size engine, its leaking fuel from the pump housing, should I rebuild or replace if it IS the right fuel pump.My seloc manual said they can not be rebuilt.:confused:
rickdb1boat
Re: 1985 Evinrude 40hp fuel pump type?
I would just replace it. It's about $68.00 and the updated part number is 438559. It is the correct pump for your engine...
Kettler
Thanks for the help, any reccomended parts suppliers?
jtexas
OMC specified those pumps for a number of years as unserviceable, but it's the same pump as the 3-cylinders from about 1968 on up - the sierra repair kit part number is 18-7820, about $12 and a half-hour of your time. You'll need gasket remover and gasket sealer, permatex is good, there's a springloaded part that'll jump out at ya, don't let it get away, careful not to score the housing when removing the old gasket material.
Kettler
That's great info too thanks. Ordered a new one from an iboats vendor and will rebuild the old one and keep it as a spare keeping any down time to a minimum.:)
