1985 Evinrude won't shut down
Enrique
Help!My 35 HP Evinrude won't shut down with ignition switch or with emergency kill switch.Tried the following:Installed new ignition switch,jumpering engine ground (yellow/black) at switch to motor to check wire to motor,before connector and at power pack-CD2, bypased kill switch.Could'nt get it to shut down after all that!!I'm stumped.Anybody got any any sugestion?Thanks.
petryshyn
Re: 1985 Evinrude won't shut down
Don't know a thing about her. Take this for what its worth, Go right to the powerpack, ground the blk/yellow right to the BLOCK. If she don't stop, I'd be checkin all the ground wires(paint under connections, corrosion, loose bolts) especially if you tried grounding right at the powerpack. The powerpack should have a ground wire of its own. check him!!! Even if the ground bolts look good, take them out and clean em.<br /> ;)
garry
Had same problem with 83 Johnson 35hp replaced the power pack and that fixed the problem
