Buck Horn Deer Farm
Thread starter- Joined
- Jul 18, 2011
- 70
Hey all, Motor has a miss at idle but when I move the advance by hand it smooths out so I want to check the timing but I don't understand what is going on here. I disconnected throttle cable, aliened arrow on linkage, pulled all plugs, put indicator in #1 and checked .464 is on the money. (all by the book) Put #1 plug in with wire from top coil put timing light on wire, disconeted the white/black wire fron switch box, cranked it over and can't see the timing marks. I put a white dot on top of the flywheel over the TDC mark on the decal and cranked it again. I aimed the timing light at the top of the flywheel and the white dot is about 120 degrees off. WHY?
