1985 johnson 120 hp tilt tube replacement
ROCKET UT
Just a question how do you lift the engine up three inches to change the tilt tube bushings?
The boat motor has about 1/2 inch play up and down.
I have the bushings but did not order the tilt tube with that much play should I get a tilt tube also, I saw in a older thred that I should put in a stainless tube but don't know why.
jmckinney
Re: 1985 johnson 120 hp tilt tube replacement
I see you didn't get a reply for your problem. I also have same problem with my 1991 120 HP johnson.
Did you get yours fixed? if so, how?
thanks, sorry I couldn't help you. need help myself
