maverick974
Thread starter- Joined
- Jun 26, 2009
- 122
The boat I just purchased has a 150 Johnson VRO. I took it out for the first time today and it ran great. It's on a 17.5 foot fish and ski. Darn near pushes the boat right out of the water on the hole shot.
Anyway, I was very pleased with how it ran but there were some concerns that perhaps you guys can help me out with.
I don't know if it's propped correctly. I got 2 props with the boat. One is a 17p and the other is a 24p. It currently has the 17 on it and that prop pulls so hard it shoves you back in your seat but I'm not sure if I'm over revving and WOT. That's where the tach comes in to play. It doesn't work so what should I look for first to get the tach working?
The other issues I had is a buzzer. The oil injection system has been disconnected so I'm assuming the buzzer was an over heat alarm. I got the boat off the trailer and idled past the no wake buoys and the alarm turn on so I shut the engine off. I waited a minute or so and then started the engine again. It sounded good so I got up on plane and then the alarm turned on again and the engine quit. I started the engine again and it ran fine the rest of the day. Stuck T-stat?????? Water was coming out of the pee hole the entire time. Does that water bypass the T-Stat?????
The buzzer seemed to be coming from the shifter.
What is that buzzer and what should I check?
Long story short?
Problem one is the Tach. Problem two is what causes that alarm to buzz?
Long story short?
