I've got a 1985 Johnson 175 with type III carbs and I'm experiencing a low speed hiccup. I've deduced from searching the forum its a lean idle problem. I understand I need to adjust the low speed orifice and make it richer but where is it and much of an adjustment? On the type II carbs it was above the carb bowl drain screw but not on these type III's. As always thanks for your time and advice in advance!
