allmuckmojo
Thread starter- Joined
- Jun 17, 2011
- 38
Ok, So Ive been trying for the past couple of weeks to get out on the water. Im having big motor issues, the motor was sold to me running, heard it rev and let it run for a few, all was good. I get home and a couple days later test it out and after about 5 minutes on choke, i turn it off and the motor bogs and shuts off. I rebuilt the carbs, i did not do an overnight soak but i was very thorough cleaning with a single wire/air gun/good carb cleaner. I can keep it running by playing with the throttle but as soon as i release it bogs down. I re-adjusted the low speed needle w/ dealer recommendation and still nothing.
When I first got the motor I did a compression test and it was good. I changed the water impeller and all seemed to be good to go. I have attached some pictures. If you can see, the top spark plug seems to be surrounded by some MarineTEX or JB weld. I was thinking of the worst but if it was a crack in the block, wouldnt compression be bad? it was 103(t) and 107(b). I looked the part up after taking the plug out and it looks to be cracked on the cylinderhead/water cover. If the gasket were bad and it was cracked there, could it be causing the bogging issue or does that seem to be an issue of its own. and other ideas? i checked out the fuel lines and they dont look gunked up and look fairly new, i removed the gas tank top for ventilation. Hopefully something simple that i overlooked.
:facepalm:
:facepalm:
