ilboater26
Thread starter- Joined
- Aug 19, 2011
- 24
Hi everybody I have a 1985 Johnson 90 that im having some trouble with.The motor was recentaly rebuilt and is still in the break in period according to the mechanic that did the rebuilt he said it would take a 30 HOUR break in period which seems very long to me it has about 6 hours on it now and runs HORRIBLE. The motor is set to run very rich during the breakin, the vro was disconnected and im now running 50:1 premix. Ok the first problem is it boggs and sputters when u put the throttle down it takes for ever to rev up to WOT but once it revs up it runs alright however when on plane if you reduce the power just a little it runs like crap and starts to bog and sputter again. The next problem is that it has is it is a PITA to start and idles rough when you go to put it in gear it dies unless you realy throw it in to gear and you must use the warm up lever to do this but it has done that as long as i can remeber even before the rebuild. And it will not run slow or idle when trying to dock or trailer the boat. I dont know if this is beacuse it is still in the break in period or what. Any advise would be greatly appriciated THANKS IN ADVANCE!!!
