1985 Johnson 90hp fuel pump
jack20
want to replace the fuel pump on my 90hp, it has the vro removed and has no # on it, anyone know the part # and where I could get one? don't have to time to hit a dealer.
thanks
emdsapmgr
Re: 1985 Johnson 90hp fuel pump
You can get one from any Bombardier dealer. Have them UPS it to you. These pumps have gone through countless part number supercessions as they have been updated over the years by the factory. There are two common pumps, both usually a dealer-stocked item. Give your dealer a call and they will tell you which you need. Make sure you are sitting down when you ask the price. Also, Bombardier does make a cheaper new replacement pump which does not mix the oil-you would have to go to premix fuel. Saves you about $100 on the pump itself.
