kenmyfam
Thread starter- Joined
- Aug 10, 2006
- 14,398
Just did a service on my water pump and impeller. Tell tale was a little slow but cooling just fine.
Cleaned out all lines, found that the dish the impeller is housed in had rotated about a 1/4" and was stuck solid. It had squashed out some of the plastic in the pump cover therefore restricting the flow. Cleaned the passages with a good and sharp utility knife. The slot in the dish had moved with it as well (obviously) so I extended it with a small hand grinder to where it should be. Cleaned any stuck rubber from the impeller with scotchbrite and re-assembled.
Result is a good tell tale flow and noticeably more flow from the exhaust while on the muffs.
I have taken several photos of the job from start to finish that I will post as I go along. (I am only allowed 5 at a time i believe)
They show the parts, procedure to a point and tools used to get to everything. Did not take the carb's off but got in with a 1/4" knuckle and a few extensions.
Any questions please let me know.
I hope this will assist others doing a similar thing.
Note, I replaced all o-rings for the heck of it.
We are now looking forward to getting out on the lake (weather permitting)
Photos from left to right here.
#1. Cover off and at each end of the upper hose you see the thermostat housings.
#2. Port side thermostat housing has the white tie wrap on it.
#3. Starboard thermostat housing is directly above the 2 spark plugs.
#4. Showing both thermostat housings. Tell tale hoses join at the bottom starboard (right hand side) of the lower housing.
#5. Shows the tell tale hose junction at the lower motor housing exit. Starboard side.
