imthemedic
Thread starter- Joined
- May 25, 2007
- 53
My Mariner outboard is fouling plugs like crazy. The plugs look like used auto motor oil is all over them. It does this everytime i run the motor. It smokes more than normal and seems to have a miss on the top end, you can feel it surging. It seems to pull hard out of the hole all the way up to top end. If i keep it wide open for 2 or 3 miles it will stall out and wont start back. The plugs have to be cleaned and a little shot of gas in the cylinders to get it started again.
History: Last year I seized the motor on the lake. The water pump went out and the buzzer didnt work. I froze the top two cylinders. The motor has two new sleaves and 6 new pistons. It was rebuilt by a local marine shop. I got the boat out this year and it wouldnt run. The carbs had gas pouring out of them. The carbs were just rebuilt with new needle and seats. I also replaced all the fuel lines,bulb,filter, added new gas. The oiler has been removed and I pre mix the oil at 50 to 1. This brings us up till current time. Now it is fouling plugs? However when it is running it is better than ever before LOL. Any HELP out there?
