speckman6408
- Joined
- Aug 24, 2008
- 30
Hello Guys: I have the above described motor whose model # is 7060525. I have a question concerning the stator.
This motor was running fine and all at once it quit--glad I had it in the tank instead of on the lake! So I got another
stator, trigger assembly, rectifier, and coil. It cranked up and ran good for about 4 hours-I cranked it at various times
over about 6 days and all at once it quit. I am not getting any fire on any plug. Looks like it is the stator again--what
would be causing the stator to go bad again. I do have a manual and it says the that the resistance between blue and
red leads of stator should be 5400-6200Ohms. When I tested my leads with them disconnected from the switchbox I
I get a reading of 4850Ohms. I am using a #2524 GE multimeter, would using this cheaper multimeter make a difference
in the reading or do I need a new stator? Also, I tested the resistance between the red stator leand and the engine
ground and I got a reading of 145Ohms and according to the manual this is withing the range which is 125-175Ohms.
Sure would appreciate any help that anyone could give. Thanks beforehand!
