Learningboating359
Thread starter- Joined
- Nov 10, 2017
- 12
Got my engine running to run on the water but it after running WO it would no longer idle right and difficult to start afterward! After cooling down, it would start so I figured that the heat of engine was causing either stator or trigger to malfunction! Took stator and trigger off and the Wires on the trigger were in bad shape! Stator was fine and within specs! Replaced the trigger and put back together with stator! It will start but won’t idle! Not sure what I did wrong!
