1985 mariner knocking but not when idleing
jonharper17
the boat idles fine but when you put it into gear it starts knocking sounds like its coming through the lower unit can you give me any advice
This_lil_fishy
Re: 1985 mariner knocking but not when idleing
Wrong section, but probably a lower crank bearing if I had to guess. Noisy under load. I had a car with a bad crank bearing, it would have a barely audible knock until you put it in gear or gave it some guess. I'm no mechanic though...
Ian
CharlieB
Does the noise occur in both Forward and Reverse?
If the shift cable has stretched it may not be locking fully into Forward.
Remove the spark plugs so that the motor cannot start.
Shift into Forward gear and step on the prop turning it CCW and make the engine turn.
Does the motor turn completely with the prop or is there any 'ratcheting as if the engagement dogs are jumping in and out?
If so then try disconnecting the shift cable, manually shift it into Forward gear and retest.
If it fully locks into gear now then replace the shift cable.
