1985 mariner V6 Trim problem
fisherman81654
I am trying to gather some information about this three ram system.
I looked through a lot of posts on trim/tilt on this site,could not find quite all the information I need.
My problem is I can't get full trim on the bottom two cylinders when up on plane.Out of the water ,it all works fine,middle cylinder also.But They all bleed down eventually.
I noticed the top of the shaft on the middle cylinder had a piece of thin round metal,looked like a clip of some sort.I think the middle cylinder is leaking,but not sure,fluid lever was fine.
I am thinking about getting a seal kit for the middle cylinder,but I don't want to order it unless thats my problem.If it were leaking,would that cause me to not be able to trim the bottom two cylinders up all the way when on plane and stay there?I think yes,I just want to be sure.
