barmeister
- Joined
- Jun 15, 2009
- 9
I would like to get some suggestions on a problem I am having with my Mercruiser 120. This is my first boat and I have been in the engine for tune up (other than wires), electronic ignition now, both fuel filters replaced, new plugs and gaps set, new distributor cap, new roter, new belt, timed at idle (0), new coil.
The boat runs great for about 10 minutes and then starts to sputter and will backfire if I pump the throttle or will stall completely. If I use the trim tab switch while this is occuring, it will sputter worse and sounds like it is loosing power to the ignition system. I have used water remover in the fuel and have added octane boost. The choke seems to be open all the way when running. I also noticed that the tachometer doesn't even try to work. the engine will run at about 3500 rpm when running fine and only at about 2400 when running poorly.
Any thoughts on where to start, or what this might be?
Thanks,
Barmeister
Thanks,
Barmeister
