DeepImpactFishingTeam
Thread starter- Joined
- Dec 17, 2013
- 20
Hi All, I removed the thermostat from my 1985 Mercruiser 260 (350 GM) and went to reassemble with new gaskets, sleeve, and thermostat of course, except the way it WAS assembled is different than the way my factory service Manual (Service Manual #9 for GM V8 Engines) which dictates the order of re-assembly. Further confusion is provided courtesy of MercruiserParts.com, which shows the order of assembly to be different than either of those two previously mentioned ways of assembly.
In short,
1) The way the thermostat was installed was as follows: Cork-O-Ring gasket, thermostat, sleeve (with lip on bottom), cover gasket.
2) Service Manual states sleeve first with lip up, then cork O-gasket, then thermostat, then a cover gasket, then a steel separator (wasn't in my motor?), followed by another cover gasket. (I would assume the new gasket I got, which has a blockoff built into the gasket is the reason i don't have a restrictor plate...?)
3) Mercruiserparts.com's diagram has thermostat, cork o ring gasket, sleeve (with lip down?), cover gasket.
Anyone happen to know which is right?? Any help is appreciated!
Mercruiserparts.com Link to diagram for reference: http://www.mercruiserparts.com/Show...r=1077&bnbr=160&bdesc=STANDARD+COOLING+SYSTEM
Thanks,
Robert
In short,
Thanks,
Robert
