1985 mercruiser 5.7, rear engine mouting
dan2744
So I got new motor in boat noticed I knocked off the fiber washer and double lock washer on one side. The outdrive is still off, how do i get that back on there? Do i need to lift the motor?
Bt Doctur
you will have to remove the mounting bolts, raise the back of the motor and insert the spring and fibre washer
