1985 Mercruiser Outdrive For Replacement of 1981 Mercruiser Outdrive Swapt?
jmw129
Can I swapt the 1985 drive in place of the 1981?
Or do I have to remove the transom assembly as well?
Re: 1985 Mercruiser Outdrive For Replacement of 1981 Mercruiser Outdrive Swapt?
Ayuh,... I guess it would depend on just What drive We're taklin' 'bout....
You've posted a pile of questions that could easily be answered in a single thread.....
jmw129
Alpha one to replace a pre-alpha.
In regards to posting multiple questions, you're recommending they all be posted in one thread is that right?
Ayuh,.... They're All 'bout swappin' a '81 305 merc with an '85 305 merc ain't it,..??
'n to cover All yer questions with just 1 answer,....
You've got Both drivelines complete, by the sounds, so everything will swap with everything else, by mixin', 'n matchin' from the pile of parts that is Both drivelines...
jmw129
Hey Bondo,
Will that require taking off the transom assembly as well? Haven't done a swapt before.
Hey Bondo,
Ayuh,... I would, but you can run the MC-1,... It just changes the mix, 'n match recipe abit,...
Personally,... I'd use the '85 transom,... It's 'bout 1 of the Best, with the most greaseable points on it....
Much after '86/ '87, the grease fittin's were disappearin' at an alarmin' rate,...
Nowadays ya can't hardly grease Nothin'...
jmw129
Very cool.. Thanks!
