ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 960
Rebuilt the carb (ultasonically cleaned) with a new OEM quicksilver kit. Looked flawless after I was done. New coils and plugs/wires. The motor takes about 5 or 6 pulls to start when cold, and idles at about 1800rpm. initially on starup, it idles ok around 1100 rpm (on hose no backpressure), but once its done loading up from the extra startup fuel, it creeps up higher. the idle timing is set about even with the block half (trigger), and the carb is closed at idle. compression 125psi on both, and CCMS reeds installed (obviously all new intake manifold gaskets too). I left my shop manual back at my house, but does anyone have the correct linkage lenght adjustments for this motor (trigger and throttle cam)? One thing: I did a DVA test on the trigger, and was consistently getting cranking voltage of 18v when the cdi website says its supposed to be 25v minimum. Is that my hard starting issue? thanks in advance here. oh... low speed needle was set correctly. I believe it wouldn't start with anything less than 3 turns out.
