jhawknz@gmail.com
Thread starter- Joined
- Oct 13, 2016
- 7
I have a 1980's Mercury 50 HP engine. I also have a power head from the next year that is also a 50 HP Mercury. So, I rebuilt one while the other power head has a hole in one of the piston heads. Long story short I was salvaging this head while rebuilding the other motor. I found a thermostat and poppet valve in the salvage power head. It got me to thinking that I should look into my rebuild and see if that motor needed a new thermostat. In the rebuild the pee hole was really clogged. I have done a complete service of the lower unit. In the rebuild power head there wasn't a thermostat or a poppet valve. So, my questions is do I put one in? Or, should I not? What year did Mercury start using thermostats? I thought is that it would cold start without a thermostat? And, the design obviously looks like Mercury designed it to have a thermostat and a poppet valve. Curious if anyone knows the answer to this. I can't find anything in manuals or online that answers this question.
