Sattech200
Thread starter- Joined
- Sep 1, 2020
- 11
Boat worked great last year. Now it dies when shifting.
Bought last year with a valve seat that let go and trashed pistons/cracked block. New block, pistons and everything else. Also changed lower end oil and both water pumps. Took out for one good run last fall. Worked PERFECT! Lots of fun.
Filled with Shell Premium from a high volume station along with the Quicksilver fuel treatments and cleaners. Quadrajet carb visually spears to be in great shape, suspect it was replaced with previous engine 4 years ago.
Last fall I Winterized boat and topped of fuel for a full tank.
Pulled boat from storage and drove 10 mins upriver to the slip. Left the boat launch fine but when we got close to slip it started to die out whenever trying to shift gears. If I rev it high then put in gear I can sometimes get it to catch and go.
When it dies out it's almost like it does it right before trying to shift gears. Dosnt this kill the engine for a split second right before switching gears? Is there an adjustment in that circuit I should look at maybe?
Want to make a list of things to check but I'm drawing a blank on this one. Nothing was changed recently.
So far I have:
1. Check timing with timing light.
2. Pull boat and change lower end oil? (Only has maybe an hour on it.)
3. Hook up external fuel tank with fresh fuel to rule that out?
4. Engine kill when shifting gears?
Any other ideas?
Also, is it safe for me to try and put in gear while still on dock lines? Never tried that before so I wanted to ask. Not looking to rev it up but just to see if it would engage without dieing.
Ittillstarts, runs and idles fine. Once I get it in gear then it seems to do fine also.
So far I have:
Any other ideas?
