1985 SeaRay Mercruiser 165 no spark at the plugs
glennj3
First time attempting to crank this season. Was running good when put away last season.
What I have now. Engine turns over strong. I have an in-line spark tester, there is no spark to the plugs. I tested the coil wire going to the distributor, no spark. The points will spark if I ground them with a screwdriver. They open & close & gap should be correct.
Please help. I had this problem last year too.
Thank you.
glennj3
Oh, I did putt a nail file on them.
glennj3
glennj3
if the points were glazed simply filing may not work, replace them.
Gotch. But I didn’t see a spark from the coil / distributor wire? Maybe I just couldn’t see it.
Bt Doctur
The points close and allow the voltage to saturate the coil windings, the instant they open the field collapses and the coil produces spark
glennj3
I’m looking for something I overlooked. I understand that with the ignition switch on I should have 12 V at the starter solenoid that the purple wire on the coil goes to. I only see a yellow wire on that solenoid terminal. It does not have 12 volts.
My be I can find a picture of the solenoid diagram?
CLi87
Did you check your neutral/safety cutoff switch?
glennj3
That’s a yellow red not solid yellow.
I’m looking at the cutoff switch now. Not sure how to test it? I found a lose wire attached to the underside, color is dark possibly purple. I have the crew driver on it in the picture.
glennj3
Can I bypass the kill switch somehow to see if that’s the problem? Thank you.
achris
More fish than mountain goat
Which switch are you referring to as 'kill switch'? (Neutral safety, shift interrupt or man overboard)
Chris...
Yellow with red stripe is the crank circuit. There will not be power there unless the key is turned to the start position.
The purple wire is ignition
glennj3
Chris...
The engine kill switch for the shifter in the photo.
Thanks.
glennj3
I didn’t post the picture of the shift kill switch. The purple wire is lose on the inside.
achris
Thanks.
That's the 'shift interrupt' switch.
And unless someone has messed with the wiring, it should not have a purple wire on it!
Here's you engine's wiring from factory..
