1985 Suzuki DT55 Tachometer question
kmdigital
Can I use essentially any marine tachometer with this motor?
It has the three wires leading out of the control box, and in checking Teleflex's web site I gather that it probably has the 6 pole alternator, therefore the 3 cylinder setting would probably be appropriate.
Is this correct? I just mounted it on a pontoon boat that already has a tach in the dash, but I wanted to verify that it will work before I connect it.
Thanks in advance!
JUSTINTIME
Re: 1985 Suzuki DT55 Tachometer question
u can use any tach
just set ity to the right poles
kmdigital
u can use any tach
Thanks, and I realize this. My question is, does this motor have 6 or 12 poles, i.e. the 3P or 6P setting? Sorry I didn't word it better.
JUSTINTIME
ask brownspoint.com
i only have the 4 stroke settings on me
