1985 Yamaha 5hp steam fixed
Sunfish12
Engine was running hot last year, replaced impeller last year, no change. pulled the thermostat, no change.
Started motor today and after one minute steam coming out of telltale. I pulled the thermostat cover and pulled the exhaust plate which is directly behind thermostat cover. The water ports were filled with muck. I started scraping all the ports I found 2 spots that were digging out. I kept digging with a metal coat hanger and 3 hours later I had 2 water ports cleared going around the cylinder. Blasted it out with the garden hose. Put it back together and now it runs cool. Telltail is now pumping alot of water.
shewm0
Re: 1985 Yamaha 5hp steam fixed
got a similar problem with a 2000 yamaha f4 4 stroke, am going to check that
