1986 140 3.0 4cl
Bt Doctur
Re: 1986 140 3.0 4cl
they adjust the fuel mix , not the air mix. in is leaner,out is richer.
depends on the carb base. If its the same size bolt pattern and dimentions.
backfiring may be a ignition issue, timing issue, burnt/damaged intake valve.
conta,imated fuel.
