1986 25 hp Johnson remote start. Small hoses location
Glastron cutty
On fuel pump there's 2 small nipples. Left one and right one. Need location of hoses. I did complete engine rebuild. From the fuel pump...the right or left one goes to the intake manifold. From there...the right one or left one goes to the carb and T's off to a small nipple behind the fuel filter. Diagram or real picture would be great. Thanks guys!!
Crosbyman
the one on the pump cover is the intake (from the fuel supply) the other nipple sends fuel to the carb
flyingscott
Fuel in goes to the round piece on the pump. Out goes to the bottom of the carb and that line must be free off to the primer. Or are you resting the primer? Thing with the red lever?
Glastron cutty
Red lever there's 2 small nipples...yes...sorry...the primer
flyingscott
Sorry spell check sucks. If you are talking about the primer ,one small nipple goes to the intake and one goes to the carb. Now if you have the third nipple behind the fuel pump. Then you need to tee off one of the smaller lines does not matter which one.
Honorary Supreme Mariner
Does not matter as the 2 wee nipples both put out the same amount of fuel when primer valve is open.
