Johark53
Thread starter- Joined
- Mar 4, 2016
- 19
Hi everyone my name is joe I'm new to iboats I have a 1988 Wellcraft 19.2 classic with a 3.7 Mercruiser that was given to me the owner bought the boat brand new for his daughter she did something to the motor on the second season. The owner then park the boat in is yard covered for 25 years when I tell you this boat is in factory condition as a professional boat builder would know this I ran a compression test on the motor cylinder 1 2 & 4 had high compression 175 pounds cylinder 3 had 90 pounds so I dropped the oil pan and popped number 3 piston out it appeared to have water in the cylinder the rings were completely seized so I remove the rest of the pistons to replace the rings. My question to you out there that if the motor only has 40 hours on it it appears the motor was overheated telling by the flap in the exhaust was completely melted the cylinders don't look scored should I hone the cylinders .5 and put oversized rings and put new connecting rod bearings? Or should I just clean everything up and put standard size rings and use the same connecting rod bearings or is it even worth fixing. It is a GM block with Ford pistons from a 460 big block with a Ford head 202 valves which are discontinued
