Re: 1986 4.3L same as 1991 4.3L????????
If it is compatible, you should try and make sure you use marine head gaskets(stainless steel I think). Also, DO NOT I REPEAT DO NOT use ANY of the electical system or fuel system parts from the engine out of the van. Re-use the marine grade starter, alternator, distributor, carburetor, fuel pump, and any other electrical or fuel system components from the engine originally in the boat. You don't want any explosions. Also, change the freeze plugs and replace them with brass ones. The cam may also need to be changed out. Someone else should know what to do about the cam because I'm not too sure what specs would be best. You may be able to use the one out of the old engine. Good Luck!
