b.lee
Thread starter- Joined
- Jul 27, 2015
- 37
What kind of RPM's should I be seeing out of my engine?
1986 Four Winns Brougham 190 5.0L 200HP Mercruiser w/ Mercruiser outdrive
Came stock with 14.5x19 3 blade prop,
I stuck a 14x19 4 blade prop on it since the original one was a little beat up.
I searched and I can't believe there aren't more topics about this...
Saturday I was at the lake, and only hitting about 3500 rpm
Then later on in the day it was only getting 3100 rpm
I got home, replaced the plugs, wires are like new and still very flexible.
I think I might replace the cap and rotor next? (probably wires too at the same time for good measure)
I know the prop I put on might cause a little RPM loss, but what should the boat do in stock form, RPM wise?
Note: The entire fuel system is brand new, except for the fuel pump (mechanical pump, looks newer, may have been replaced by the previous owner)
The old plugs didn't look too bad either.
