1986 6 hp Johnson Gearcase Cover and Seal
ruddy mudder
Replacing the gasket between the gearcase cover and seal and the lower unit, should that have some kind of sealer put on it?
saltchuckmatt
I assume you are installing gasket 324637 keeping the gearcase sealed on the top. No sealer should be required but I don't think it hurts either. Let's see what others say. As long as you have that part out did you replace the other seals?
