ShoestringMariner
Thread starter- Joined
- Apr 18, 2015
- 1,605
I recently freshened up a 60 hp Evinrude for my brother. Three cylinder 1986 model.
A few times lately it has refused to start. In both cases it took removing the spark plug to check for spark while cranking that actually caused the motor to fire. In both cases the motor would not fire cough or a sputter at all on either choke or manual fast idle.
The fuel line was full. Primer bulb rockhard. Disconnecting caused fuel to spray out of the coupler connected to the hose. It happened once on a coldstart and happened once after use and one and a half hour cool down. Both times identical process. Both times removing one spark plug caused it to immediately fire. (more specifically fire elsewhere in the motor. Not fire coming out of the hole) but exhaust smoke was detected coming out the top hole. Starting attempted with motor in the water. Not on muffs
This was a motor I picked up last fall. I replaced all the fuel lines with standard correct ID fuel line from an automotive parts house. I used Evinrude fuel zip ties. These were not formed OEM hose replacements. Re-built the carbs with full kits.
What we find really odd is that nothing works until one spark plug is pulled. Then it fires almost as if the motor cannot breathe. Like the fuel air mixture isn’t getting in until we open it up. Do two-stroke suffer vapor locks of sorts in this case? Stuck reed valves? Fuel pump issue? Crank case leak?
I lent this motor to my brother. I’d really like to get it sorted out for him so he can get the rest of the season in.
Thanks in advance
Thanks in advance
