1986 60 hp Mercury gas leak from carb area
1986bassbuggy$@
Just bought a 1986 60hp merc that has a gas leak coming from what looks like the top carb, when you press the primer bulb it really spews.
michaud500
Re: 1986 60 hp Mercury gas leak from carb area
Not sure what type of carb you have but I have 1969 50hp and had the same issue. I am in the process of rebuilding also, but noticed when I was removing the carb from the motor that the top cover for the filter where the fuel comes in had a bit of movement. My guess is that the fuel leaked from there. But after cleaning and rebuilding, you should rebuild the carb.
